Beneteau 323 Filters
Nov 5, 2015
11
Beneteau 323 Punta Gorda, FL
Anyone have a list (including part numbers) of all filters (oil, fuel, water) that need periodic cleaning or replacement for a Beneteau323?
Beneteau 323 Annapolis MD
You did not say what engine you have, but my B323 2006 is a 3YM20.
Oil filter, if shopping at West, a Sierra 18-7910, though I think there is a new number for the shorter filter. Yanmar part # 119305 (-3150 or 3151 or 3152, again for the filter size, but all have the same base).. I just got a Fram PH6607 that AutoZone shows as being for the 3YM20 (I've not yet put one of these on the engine, thought..
The fuel filter on the block, Yanmar 104-500-55710
The Racor 110 fuel filter off-engine : ??? Should be easy to ID in the stores.
DougM
Jul 24, 2005
2,242
Beneteau 323 Manistee, MI
I have a 2GM20 and the secondary filter is a Fram part# that ends up being an identical twin to the OEM filter, and not as expensive. Shelf item at AutoZone.
The primary filter is a Racor 110.
Nov 5, 2015
11
Thanks! I have ordered both fuel filters and will replace next weekend.
I have a Racor 120 filter to replace the 110. The mounting bolts and hose connects are the same as the 110. Actually, the main fitting may be the same on both filters, though I doubt it. I'll find out in a few days.
