If your cutlass bearing is similar to
the one in my '94 OC400, the bearing is nothing but a plastic sleeve. If it needs replacing, you'll need to order it from Beneteau and it will take a while to get. Try this; remove the old one, rotate it 180 degrees and re-install. The packing gland might be a different story; mine is a dripless unit with its own water intake thru-hull.
