Beneteau 311(2000) refrigerator fuse unit location
10
Beneteau 311 Bradwell
Hi all,
I have a Beneteau 311 (2000) and recently the refrigerator has stopped working. After investigation it appears that there is no electricity getting to it leading me to believe that a fuse has blown. After lengthy searching I can not find a fuse for it anywhere on the boat. Could anyone help me out and enlighten me as to where the fuse unit is located for the refrigerator?
Thanks.
Usually there are two breaker/fuses in the circuits. One is the fridge fuse or breaker on the panel, the other fuse is built in on the electronic module (if it's an Adler Barbour/WAECO unit at least). If, however, you're not getting any power to the unit, then it could be a connection somewhere along the wire run. Good luck playing detective.
May 20, 2013
10
There isn't a breaker on the panel for the fridge. The fridge is actually a Frigoboat. I have had an electrician in and he can't find a fuse either. I am stumped. Any ideas? Please!!!!!!
reworb
Apr 22, 2011
234
Beneteau 311 Ft Myers Beach
I'll walk outside in a a half hour or so and see if I can find one on mine.
reworb
Apr 22, 2011
234
I have a 2004 311 and also have a Frigoboat refer. However I have a switch/breaker on the electrical panel (maybe Beneteau added the switch in later model years). I traced the wires all the way back to panel from the unit and there is no fuse on either the wires or unit itself. Just as an aside do you always leave the unit on? I do but a lot of people turn the refer off when they are not on the boat. Sorry I couldn't help
May 20, 2013
10
I really appreciate you looking. Thanks for that. No we don't leave the fridge on when we are not on it. We turn the batteries off. I am stumped then as I can't find a fuse or a breaker anywhere.
Thanks again.
Widgeon, then maybe, just maybe, your fridge power is tied to one of your red switches in the aft cabin. Your main battery on switches. Is that where the power to the fridge comes from? Means whenever you turn your house bank on the fridge comes on? Do you not have the two red switches and one black in the aft cabin?
It could be that the fridge is a dealer added option, not factory, so could have been wired by a chimp! :)
Beneteau 323 Annapolis MD
If you have a fridge pumpout breaker, mine is on the same breaker as the fridge itself. B323.
May 20, 2013
10
stu Jackson
Only 2 main red switches, 1 for domestic use and 1 for engine.
You may be right about being fitted by a dealer, in which case I may never find the fuse location, if it exists at all.
May 20, 2013
10
RON20324
Don't have a fridge pump out, only a drain pipe from the fridge. Thanks for the suggestion.
Apr 14, 2010
195
Jeanneau 42DS Larnaca Marina
According to the B311 owner's manual, there's a 10A frig breaker on the main panel. It is not possible not to have a breaker as it would be in violation of just about a dozen marine and electrical codes. Keep looking and tracing wires.
It is probably a number 8 wire on the back of the panel unless there is that goofy WAGO connection block- a source of troubles itself. The wires are probably numbered at both ends for identification.
May 20, 2013
10
Lee Hadjiosif,
Thanks for that information Lee, I will notify my electrician and double check the panel.
May 20, 2013
10
Ron20324,
I will certainly get the No 8 wire checked out, to see if it is relevant. Many Thanks.
reworb
Apr 22, 2011
234
RON20324
Wow they made a lot of changes from 2000 to 2004. On my boat in the head under the sink there are 3 valves connected to a pump, depending on which valve is open the pump draws water from the fridge drain; the shower sump or bilge.
I have an owners manual although it is a 2002 Rev00 version and the diagrams match my boat. I checked on line and that's the the only version I can find:
http://community.ilovemybeneteau.com/boats.php?boat_id=26&type_id=1.
I'll check later on today and see if have have any documents on the fridge
May 20, 2013
10
REWORB
Thanks very much, let me know if you find the fridge fuse location. It seems like someone has altered the feed and I need to discover how.
reworb
Apr 22, 2011
234
If you have the same model as I do (Paris 35F; there is a sticker on the top of the unit with the model) the unit does not have a fuse. The installer is expected to install a 15 amp fuse between the battery and switch and the unit. There are fuses on the unit on other models but not this little one.
I have attached a PDF of part of the manual that has a test procedure and two diagrams
10
REWORB
Thanks for taking the trouble to send the manual for the 'Paris 35F', I am planning to continue my investigations tomorrow to find where the electrical feed is from, together with the 15 amp fuse.
