bend in upper mast side to side
1
- - kazoo
can I remove this by upper tension vs. lower opposite tension my first attempt made me a little nervous becuase the turnbuckles on the upper on the side i am pulling toward is 75%closed and the opposite upper turnbuckle is nearly open. this helped reduce the woop ti do some , however using a loos guage the tensions are being matched as I go. (loosen one tighten the other) It is nerve racking not knowing if there is a simple and safe order to address this, and if this is worth the concern. Any suggestions please on this or what could have caused this, I am a relatively new owner on this boat
E
ed
Right track
It sounds like you are going about it the right way. Also make sure your mast is plumb. You might find a book or two about rigging for help.
