Bemusings with Rummage Sail
Oct 2, 2008
1,424
After considerable assumptions, suppositions, half drunken research and testing, I have come to some important conclusions regarding sailboat electrics. First of all, all cable must be the largest that is available on the shelf at West Marine or the general electric medium transformer plant nearest you. Secondly, all connections must be made with a custom built $10,000 crimping tool available at a single manufacturer somewhere in the frozen north east. Thirdly, disregard all shorter connections recommended by the manufacturer and go with the longest possible run of largest possible cable. And fourthly, and perhaps most important of all, all connectors connecting bolts terminals and cable must be rendered in solid gold. Anything less than that risks too great of a voltage drop and poor performance by the charging equipment, and miss leading data furnished by the battery monitors.
Jan 4, 2006
7,643
You certainly can't go wrong with that appraoch ............... however you may find your boat overweighted and your wallet underweighted.
It's more a matter of doing a detailed analysis of what you want at the load end of things as well as good installation practice.
Oct 2, 2008
1,424
You certainly can't go wrong with that appraoch ............... however you may find your boat overweighted and your wallet underweighted. It's more a matter of doing a detailed analysis of what you want at the load end of things as well as good installation practice.
Of course. All the above was intended to elicit amusing responses. I have certainly found my wallet underweight and the boat is definitely overloaded!
Nov 26, 2008
1,970
Endeavour 42 Cruisin
I had a very difficult time wiring all the data cables between the chart plotter, the gps antenna and the AIS with 8 gauge wire. But it was definitely worth it. I won't have to rewire for at least a year.
DougM
Jul 24, 2005
2,242
Beneteau 323 Manistee, MI
You should try it with 0000 cable next time....
Jun 11, 2011
1,243
Hunter 41 Lewes
The larger the wire, providing it is installed low in the boat, can allow you to reduce Draft by cutting a similar weight from your keel!
Nov 6, 2006
10,214
COLD here in south Louisiana.. I am still in the half drunken research phase.. I have to report that use of the Kirkland St. Croix Island Spiced Rum (available at Costco) is a fine way to do this research. I can't remember what size my wire is.. but the engine cranks fine!
Oct 2, 2008
1,424
FURTHER BEMUSINGS BT RUMMAGE SAIL Shortly after my wife left the boat this morning I was at last able to test the latest Maxwagger. The results, which I will publish soon, have been expressed, in the most convoluted mathematical Spanglish I could find. I'll post pictures and graphs as soon as I can make them (up). Of course to test the Maxwagger I had to connect it to my friends pugleblugger, which I've borrowed quiet often. It may be old but can certainly still render some useful data. There are newer more modern puglebluggers available but that are quiet hard to come by, being very expensive.
Oct 2, 2008
1,424
I went ahead and soldered the circuit board of my chart plotter directly to the battery terminals. Can't see a darn thing with my head stuck into the battery locker but no worries about ground faults. :D
Nov 26, 2008
1,970
I would have done that too but the 1,000,000 cfm exhaust fan for the wet cell battery fumes was too loud.
Nov 14, 2013
238
Catalina 30 MkI 1983 TRBS Westbrook, CT
Whatever you do just don't let the magic smoke out of the wires. :naughty:
May 24, 2004
7,213
CC 30 South Florida
I used to buy a rum in St. Croix for $0.99 a bottle; the locals said it was real good for removing stains from a driveway. Kloudie I know the one you drink is good stuff but your posting brought back some memories. I think it was called Cruzan rum and it could tear out your guts and produce a massive headache. That was more than 30 years ago but it seems like yesterday.
Dec 31, 2012
91
Catalina 28 mkll #649 Port Charlotte, fl
You guys are killing me……..:D
I know I have a boating problem,,,,,, I fully realize that whenever I sober up…. Now PLEASE pass the RUM de dum so,s I can regain my insightful self…. And, ahhh where did I put those wire cutters….
Beneteau 323 Annapolis MD
.... I think it was called Cruzan rum ...That was more than 30 years ago but it seems like yesterday.
If you get the next grade up of Cruzan, it is pretty good stuff. Heck, even the "sailors-grade" stuff is good.
"Someday my ship will come; 'Till then I'm cruis-in on my Cru-zan Rum". Them Eastport Oyster Boys song.
Nov 6, 2006
10,214
I remember buying Cruzan in the BVI back in the '80s for $0.99 for a fifth.. If ya mixed it into a painkiller or a rum punch, it was fine.. A couple of stores here in Baton Rouge carry the "good" Cruzan .. I remember Mr. Caldewood's rum too.. "...you sleep like a baby, mon.. no hangover..." is what the guy filling the bottles told us. uuhhhh.
