Belt Size
May 12, 2004
1,505
Have a Yanmar 3ym20 in my boat. Last Sunday, about 200yds from my slip, the belt to the raw water pump decided to disintegrate. Was able to get to slip before overheating. Going to replace both belts. Have the alternator belt off. Two questions.
1. Does anyone know the size of the raw water pump belt? There was hardly anything left of it. I can't find anything in any manual.
2. Besides going to my Yanmar dealer and paying an outrageous price, can I get a belt at a local dealer like NAPA? If so, what brand would be recommended?
Dec 1, 1999
2,391
Hunter 28.5 Chesapeake Bay
I second the motion about buying Gates belts rather than Yanmar belts. Here is a pic of a Yanmar belt that was in service on my boat for less than 50 hours. I had no burrs or nicks in the blocks/pulleys. It was just poor quality control on the part of whoever makes belts for Yanmar.
Likes: Roland5048
jviss
Feb 5, 2004
7,090
Tartan 3800 20 Westport, MA
I would wonder why the belt disintegrated. Is the pump seized, or perhaps partially so?
Agree on the Gates belts, get the highest H handling available in your required size.
Likes: Roland5048
Jun 6, 2006
6,990
are you driving a high output alternator? Common problems are getting the wrong "V" angle belt (there are two), trying to drive too much alternator with too few belts (50 amps is about the limit for a single belt). No belt, no matter how well manufactured will survive being use on the wrong pulley (v angle) or being overloaded.
Likes: Roland5048
May 12, 2004
1,505
Thank you for the quick responses. I guess I could use a small dia. line and wrap around the pulleys to get a circumference. It's just too tight in there to get a tape measure. Maybe a tailor's tape might work. Would I fine Gates belts at NAPA?
May 12, 2004
1,505
Belt more than likely let go because it was almost nine years old and over 600 hours on it. These were the original belts from when this motor was brand new when I had it put in. No lectures please, thank you. I know better.
Pump is not seized. It is fairly new. Will be replacing the impeller also, although fairly new, due to it's running dry for about two minutes.
Alternator is stock that came with motor. 60 amp, I believe.
Beneteau 323 Annapolis MD
My 3YM20 came with a 20, but with stretch and age, it was too long to be adjusted tight enough. I put in a 19 and it gives me a proper adjustment travel. About a 2 inch chunk of the inner half of the belt thickness had fallen off. I saw it before it broke.
Bob S
Sep 27, 2007
1,813
Beneteau 393 New Bedford, MA
Recommend keeping a spare on board once you figure out the size.
May 12, 2004
1,505
Measured out at 20 in. using a cloth tape. NAPA is ordering me a 19 and 20 inch. Can bring back the one that does not fit. Bought an alt. belt from them, also. It's in NAPA packaging but is made by Gates.
A spare will also be ordered.
Hope to up and running by the weekend.
Will post the sizes after all is said and done.
Thanks for all the responses.
May 12, 2004
1,505
I'm surprised no one caught this gaffe. Just occurred to me.
The impeller did not run dry... it did not run at all due to the belt giving way. Replacing anyway.
