If I am reading and interpreting correctly, I only need ONE (1) vented loop:
Vented Loop between bowl and pump.
I have a below waterline head, and holding tank ONLY, no option for overboard. Looking at Peggie's book, and the Raritan PHII, the vented loop for discharge from pump is only IF OPTION exists for having connection between the sea and head discharge, either directly plumbed to an outlet seacock or through a y-valve to an outlet seacock.
Finally getting close to completion of the holding tank upgrade. 25gal AND it is mounted in the bow, resulting in regaining the below bunk shelving and footwell in the V-berth that a P.O. utilized for an improperly installed and improperly vented holding tank. :O)
