Behind the mast furler
166
Nonsuch Ultra 30 Gulfport, FL
Time for a new main sail on my Island Packet 27. I've been thinking of a behind the mast furler like the Harken, but not the CDI. I would appreciate and feedback from those with experience.
Reef early
>>ron<<
Apr 3, 2008
166
All that I've heard and read is that the CDI system will not stand up like the Facnor or the Harken systems.
>>ron<<
Apr 3, 2008
166
Sorry about the Avatar having the picture of my rhodes-22 and her name. As soon as i figure out how to change the name and the picture on the Avatar I'll bring it up to date. New boat is Good Idea
Reef early,
>>ron<<
Jun 9, 2008
1,792
- -- -Bayfield
It seems like a lot of expense for such a little boat. Selden used to make a retrofit furling system for mains that attached to the trailing edge of the stick, but don't offer it anymore. Now they say it is about the same price to replace the whole rig with the system incorporated into the spar. It is a very good system. The only behind the mast system I really messed with was on a 47 footer and it was built by ProFurl and it was a nightmare.
Oct 22, 2008
3,502
- Telstar 28 Buzzards Bay
Why would you do this?
The boat's mainsail isn't really big enough to warrant needing a roller furling/reefing system.
The sail shape would be horrible when reefed, which is the last thing you want.
The system would add weight aloft.
The system would add windage aloft.
You wouldn't be able to have anything but a hollow leech main, and would probably lose some sail area to the hollow leech, in addition to what you'd lose at the luff to accommodate the furling system.
You're adding complexity to a system that really doesn't gain any benefit from it.
BobM
Jun 10, 2004
3,269
S2 9.2A Winthrop, MA
Seems like a lot of money to spend for reefing, given the other options, so I assume it is also for convenience (avoiding flaking and covering the main). Personally, given the relatively small size of the sail I'd suggest a stack pack / lazy jack set-up. Have you considered that, perhaps with Harken battcars (should allow the main to readily drop down vs. slugs) as an alternative?
http://www.harken.com/mainsail/Mainsail_Novak.php
However, if you are really looking to avoid going on deck then the CDI isn't a bad alternative either.
COOL
Feb 16, 2009
118
Islander 30 mkII Downtown Long Beach
I second all of Sailing Dogs statements above.
If you are an invalid who sails single handed,
such a system may make sense for you.
Otherwise it is another way to further degrade the
sailing performance of your boat, for a little convenience.
Jan 22, 2009
133
Hunter 31 '83_'87 Blue Water Marina
I disagree with the others.
Anything that makes my day easier, I'm for.
I don't go sailing to go fast. I borrow my brother's Sea Ray 23 for that.
I go out on the boat and water for selfish spiritual reasons.
I have met a lot of people with in-mast furlers who love them.
Behind the mast is the only retrofit that makes economic sense.
I didn't take up sailing to exercise or test myself or anything like that.
If you want it, get it if you can, but let me know what you got and how you like it.
I would presume the naysayers have no experience with it. Just a guess.
Oct 22, 2008
3,502
You can get a lazy jacks system, like EZJax, that allows you to deploy/retract the lazy jacks from the cockpit. Combine this with the reefing lines, main halyard, topping lift and outhaul all lead aft, and you'd be able to raise, drop or reef the main from the cockpit with little trouble. Add a fully battened mainsail, and it will be fairly easily managed from the cockpit and give you far better sailing performance than a roller reefing main setup, with less weight aloft, less complexity, less windage, etc...
Jul 1, 2004
567
Hunter 40 St. Petersburg
Hey Shooter, I like your post
but not because I agree. I don't, at least not entirely. I do like that you're speaking your mind.
I'm going to respond to your comments though. We can discuss it further over some cold ones. :)
I disagree with the others. Cool.
Anything that makes my day easier, I'm for. Isn't that what Sea Rays are for?
I don't go sailing to go fast. I borrow my brother's Sea Ray 23 for that. Oops, sorry.
I go out on the boat and water for selfish spiritual reasons. I'd suggest that sailing poorly probably isn't terribly spiritual.
I have met a lot of people with in-mast furlers who love them. He's not asking about an in-mast furler but even those don't address the shape issues.
Behind the mast is the only retrofit that makes economic sense. Oh my. It's more expensive than lazy-jacks so that can't be true.
I didn't take up sailing to exercise or test myself or anything like that. You took up sailing to sail, right?
If you want it, get it if you can, but let me know what you got and how you like it. Absolutely.
I would presume the naysayers have no experience with it. Just a guess. In my case you guessed right.
For me, sailing well is usually intense. Doing it well is a kind of religious experience. I want my boat to perform. I think rolling mains take a hit in performance. If there were any performance to be gained then the racers would be doing it. And they aren't.
I do understand why many people like them. I'm sure they can be optimized.
I've read the opinion about how, 'I'm not going to be racing.' I'll just say that performance means many things. It's not just about knots or degrees of heel. For example, I'd find it tough to give up the simplicity of releasing the halyard and dousing the sail unattended in seconds while shorthanded in heinous conditions.
I don't mind some effort when I sail, I do confess to having a dodger though . . .
Jan 22, 2009
133
Rick,
I'm a 60yo Huck Finn.
I want to hang out on the bay on my boat.
I have no jacks and no main furler.
New to sailing. Bad knees. Bad back.
Short, fat, old and ugly.
Decided to get the boat now because later would be worse.
Single hand more than I prefer. Thank you Yanmar.
Spent too many years thinking someday I'll get a boat.
You know, in the sixties I had '66 SS 396 I drove as mine in '67.
Speed and racing and adreneline rushes are good but they're not my Gestalt.
In '71 I had a Triumph Spitfire that I loved. Wanted a TR6 or AH 3000 but . . .
I'm a mellow person who just wants a way to enjoy "me time" on the bay. I've got it.
I'd like to make using the sails the easiest I can. If you're already getting a new sail, behind the mast furling seems similar in cost to jacks and batcars or stak paks.
Seems easier to reef, too.
I'm just sayin' . . .
May 23, 2004
3,319
No one mentioned a roller furling boom option. That could be a possibility but I have no experience with that at all.
I single hand a Catalina 30 on the Chesapeake Bay. I don't have lazy jacks or anything like that. I have a full batten main and I drop and lower it the old fashioned way. I am tempted to put jacks on it but we shall see if I do. I would rather get a new main with two reef points first.
Reefing a boat isn't rocket science. If you anticipate the need for a reef (I.E. high wind forecast) then do it at the dock or at anchor. It is easiest to do it before the wind builds up too. It is much easier to reef the boat and shake the reef out if you don't need it than it is to shake a reef into it when the boat is over 25 degrees and blue water is coming over the bow.
MrBee
Dec 30, 2008
425
Irwin 34 Citation Middle River, Md.
Lots of people with lots of different needs/wants. What one likes another may not....What works or is ok for one may not be for the other...Whats easier for one may seem a pain for another. Try it, see if you like it, if not sell it and try something else till you have what works best for you and your situation...
Brian
