Been in my 45cc for 3 days!!! Complete newby!!
Jun 29, 2017
2
Hunter 45 CC San Francis
hair curler in make up table plug killed half the boat? What's up? Shore cord in put looks good. Says charging 12.5.
Dec 25, 2000
5,944
Hi David, absorption charge rate for our house bank around 13.6. Bulk rate around 14.3. Seldom use the hair drier anymore (not much hair there you know), but worked just fine whether connected to shore power or on the inverter. What is the dock power pedestal rated at, 20amp, 30amp, ...?
Mar 30, 2009
19
Hunter Hunter 456 Rock Hall, MD
David,
I have a 2004 Hunter 456, basically the same boat. GFI at nav satiation, aft head , and makeup table, I think. Check in forward head also.
Jun 6, 2006
6,990
you need to identify the circuit that went down and, more generally, understand which 120 volt outlets are on which circuits. As a general rule the boat AC is divided into port and starboard by the GFI outlets. One GFI at the beginning of each circuit that is protected by that GFI. The AC panel circuit breaker controls all the circuits so as long as that is not tripped there should be at least one GFI tripped.
Oct 27, 2016
0
Seattle
And now a word from the sponsor...
Replacement in-deck solar panel
Finally, a drop-in replacement for the in-deck solar panel on Hunters built from the early 90s through the mid-2000s. Improved for longer life and greater output.
See the product
