E
Eldon Burg
While Decommissioning my H34 last fall in noticed that the bedding that surrounds the strut that supports the prop shaft has a soft spot. no blister or leaks were noted.Your thoughts appreciated vis:1. ignore2. remove the soft spot area3. Remove it all and start from scratchWhat would you recommend regards appropriate product/procedurethanx
