BBQ Comments ?
PKFK
Jul 12, 2004
206
Hunter 36 Ottawa
Lots of questions from my corner lately - thanks in advance for your inputs.
I am also looking to replace my BBQ (an older Force 10 "log-shaped" propane unit that blows out in the slightest breeze).
From what I can see, there are 3 main brands - Dickenson, Kuuma, and Magna.
I have heard good comments about this unit:
http://shop.sailboatowners.com/detail.htm?group=1414
I am looking for a new BBQ on the larger end of the size spectrum - and want one that has decent resistance to the wind.
Any good / bad comments on BBQ's that you want to share would be appreciated.
Thanks !
Paul
Sep 24, 1999
1,511
Hunter H46LE Sausalito
for us, fourth try was a charm
Living aboard in windy SF bay, we've had terrible luck with three different grills, none of which were able to stay lit on a typical 20-25 knot summer afternoon. The first was a Magma kettle type, the second was a Force 10 log type, the third was a conventional Dickinson Sea B Que, the one you linked in your post. While it was better than the previous two, it really didn't stand up to any sort of breeze.
Finally, we bought a new round Dickinson Sea B Que, the one with the round burner, and so far this summer it's never once blown out. Better yet, it takes far less propane to cook a meal than any of the previous three required.
Cool thing about the new grill, is that it will actually bake a pizza.
Apr 28, 2008
60
Hunter 340 Havre de Grace
I have had the sea b que for years and find it to be a great unit. I also can take it ashore and with the legs it sits nicely for a shore cookout with a small gas bottle. My 340 has a 2 tank compartment so I have a seond tank which i can attach to the unit with a hose DIckenson supplied. Makes for an easy reliable set up.
zeehag
Mar 26, 2009
3,198
i love reading about folks and their bbq problems on board---each has to get the most expensive, least user friendly item out on the market--i love my weber smokey joe--i have seen them mounted on rails of other boats and just laughed as they are the best bbqs in the size range i have ever found. they are black and they cook well. i store mine with the tile i use under it in my lazarette...and i only paid 2 1/2 dollars for it...LOL..i used to use magma, but they blow out in slight breezes!! so do dickinson and so do force--all are soooo expensive for the lack of being able to use them...i still have the magma on the rail of my ericson 35, but i USE the weber on my formosa as much as or more than most boating folks i have seen--mine stays lit in wind....AND i use my favorite cooking fuel---REAL mesquite....
PKFK
Jul 12, 2004
206
Hunter 36 Ottawa
I hear you - nothing beats the taste of stuff grilled on mesquite (And the coals *like* the breeze !) - however - we sail on an inland fresh waterway - and dumping ashes in to a quiet anchorage will not win you any friends.
So....I am more or less stuck with the propane option - since we are not on the ocean, we get less breeze - so I am hoping that one of the units suggested here will suffice. I will look at the Dickenson ones mentioned and see how it goes.
PKFK
Jul 12, 2004
206
Hunter 36 Ottawa
If it works on SF bay - it must be windproof !
Living aboard in windy SF bay......
......Finally, we bought a new round Dickinson Sea B Que, the one with the round burner, and so far this summer it's never once blown out. Better yet, it takes far less propane to cook a meal than any of the previous three required.
Thanks for the input on your experiences. The Dickinson's are "supposed" to be better in the wind - glad to hear that your real-word test bears that out. I will look around for the round version !
Thanks,
Paul
zeehag
Mar 26, 2009
3,198
i empty my ashes into a large plastic garbage bag and put it into a waste container at fuel docks when i need to rid the boat of it--folks in houses can use the ashes to prevent snail infestations in their gardens also--i donot have a house so i leave mine in a container made for waste---every fuel dock has them --there really is NO excuse for neeedless pollution...biodegradables--go for it--other stuff gets contained.~~~~~_/)~~~~~~AND--i donot limit where or when i sail or what kind of water i sail upon..or even where in the world i might sail --LOL....
larryw
Jun 9, 2004
395
Beneteau OC400 Long Beach, CA
Prefer using coals, but don't like dealing with ashes. Gas grills OK, but hard to keep lit, like soggy butts, and over the years, I've found I do very little Q work on board, prefering to use the stove-top. I have a great iron skillet that'll sear a steak to perfection.
May 6, 2004
916
Hunter 37C Seattle
Re: for us, fourth try was a charm
I just bought one of these http://www.bbqs2go.com/pages/supremeparty.asp
I was looking for a grill with a shelf. It gets hot with the flame on low and the lid down and stayed lit on low in about 8 knots so far. Seemed to grill veggies without burning. Food can't fall out or down through the grate. The single rail clamp is not sufficient. I added a side clamp/arm taken from my old grill to the side of the new one.
zeehag
Mar 26, 2009
3,198
as far as i have seen,. all the bbqs even the weber have aftermarket things and doodads for the bbq--shelves for inside some for outside and whatnot--check out the sites online--may find what you need there---even ebay has stuff anymore--LOL--there are also hotdog and hamburger things --rack with handle for turning --that are available and would be good for veggies!!
