Bayfield dimensions
shawnkfl
I need to build a trailer for a B-25 for a friend. His boat is in a slip currently and costs around $200.00 to pull it just to get some measurements. I was wondering if anyone has a B-25 on the hard and would pull some dimensions for me. This .pdf shows what I need.
shawnkfl
pictire didn't post
well. i see my picture didn't post. if anyone can help me out, i can email the spec sheet showing the dimensions i need.
Sep 19, 2006
643
SCHOCK santana27' lake pleasant,az
i have the screw jacks i removed
from my trailer when i custom fit it to my boat . that would at least get it on the hard so you could fit it
steven gardner
25 bayfield trailer
I bought a 30 aluminum trailer that was set up for a scarab type boat. I have more trailer than I actually need. I made a guide for my keel" drive on guide" and placed three homemade screw jacks on each side. the 5/4" decking board that I used is on a swivel point. I then hung the boat on a lift and adjusted the cradle on each side to support the boat. I used a 5/4" X 6" board to cradle the side of the boat becuase I have seen where pads actually distorted the hull on some boats. By using the screw jacks when I launch I can drop the back of the cradle and then when I drive back on the trailer I just snug up the back of the cradle.
