Battery Trickle
Drew
I'm trying to figure out what size solar panel to use for trickle charging a 24" 12V deep cycle battery. Battery specs I have (in Greek, to me) are as follows: REF.CA@32(degrees)F = 625 CCA@0(degrees) F = 500 Mins.@23 amps = 150 Mins.@25 amps = 130 20 A.H. rate = 75 All I run is lights and an occasional tape deck off the battery - no engine starting. Is a five watt solar panel too much for trickle charging when I'm away from the boat? Too little? Thanks for any advice. Drew
May 7, 2004
51
- - Fern Ridge Eugene OR
Trickle charger
We have a single 12 volt battery and we have a 10 amp solar charger and it works great. If you have a west marine catalog it will have a chart that will help you in figuring out the size and if you will need another switch or if that one that is built into the solar charger will work. Rob
