So far everything I've read about batteries says the longevity is severely compromised by deep discharge. This is based on number of cycles. However, total amphours extracted from the battery over it's lifetime would be a more meaningful measure of its useful life. I haven't been able to find this data so, using the data available on Deka's tech page, I calculated it. My house batteries are a pair of Deka AGM 4Ds.
Unfortunately I could not copy the data to this note and preserve the format. The first column is the percent discharge, 2nd is life expectancy of the battery based on number of cycles assuming 50% discharge is "normal," 3d same based on total amphours extracted from the battery. The bottom line is the life of the battery is shortened by deeper discharge but not nearly as severely as counting cycles would suggest.
25% 250% 125%
50% 100% 100%
80% 54% 86%
100% 41% 81%
Here's 2 links to my calculations; first link numbers, second excel. You can plug the data from your battery into the spreadsheet if you're interested.
http://dl.dropbox.com/u/15870341/Battery longevity data.numbers http://dl.dropbox.com/u/15870341/Battery longevity data.xls
Geoff
25% 250% 125%
50% 100% 100%
80% 54% 86%
100% 41% 81%
Geoff
