Depends on what you saw
Battery makers will only make warranty tests based on a LOAD TEST, not on a multimeter. The results tell you different things.If you saw a load teste for $29, and it provides enough load to test your batteries without burning up, sure, it is a valuable tool. The real question for any battery is not "what's the voltage" but "what's the voltage under load" and for a car-sized battery, they may typically throw a thousand watt load on it, to simulate a starter motor. You won't get that from headlights and such.
