The alternator field disconnect (AFD) feature only works if you have an easily accessible field wire to interrupt. With an external regulator this is easy but with a stock regulator not quite as easy. The AFD circuit breaks the field circuit a split second before the load is disconnected thus avoiding disconnecting a load from the alt with the alt pumping out current and blowing the diodes.An in the process of adding another battery to my boat. I was looking at Batt selector switches and my question is what are the switches with alt leads used for ??
Just Paring an old battery with a new battery is not good for new battery. Because as a battery ages its charge rate and state at rest changes. Always make sure batteries are of the same age make and size. See that they are equally charged. Then you can tie 1,2,3,4 batteries together to create one large battery bank.If all you are doing is adding another battery just connect in parallel to one of the existing batteries. I'm not thinking you would need 3 separate battery circuits (start, house 1, and house 2???) Just make the house bank bigger and use the existing wiring.
