I decide to figure out which battery switch location on my boat was start and which was house. I surmised the easiest way was to disconnect the positive lead of one of the batteries and see which position of the selector switch provide no power. It didn't work out that way, as long as I had a battery connected I had power to the dc panel ( All, 1, 2) except when I went to the off position. I shut down shore power thinking the battery charger was lighting the panel not that either. I don't think I have a back feed issue. I know the batteries have been replaced once, and a genset was added. I have to think something is wired incorrectly. I guess the next thing is to look at the back of the switch and see where the battery cables are connected. Any suggestions or am I thinking wrong about the battery selector? I also believe the genset is using the same starting battery as the aux engine, I will trace that cable run.
