Battery Switch Query
Feb 25, 2014
69
Hunter Hunter 30 Lake Lanier
Several of the boaters on my dock were up a couple weeks back. A new boat owner moved to our dock and she was asking if she needed to switch her battery switch to Off, as she was not going to be up for a couple months. All of us had battery chargers on the boats.
This gave way to a lively discussion, with some boaters saying yes some said no and others had not clue. Wanted to post this question for the forum. We do have many nights where the temp goes below freezing, but most days the temp is above freezing.
Cheers and everyone stay safe.
Catalina 34 Casco Bay
So does the battery always feed to the panel? A battery switch sure makes it easier to shut everything off.. As an aside, long term battery charging is not good.. Tenders like Deltran or conditioners like Xantrex are the better option.
Sep 25, 2008
7,751
Alden 50 Sarasota, Florida
There is no one, single correct answer. Depends on how the batteries are wired, what runs off them, e.g. refrigerator. Chargers are not typically wired through a battery switch so that is irrelevant.
Likes: Justin_NSA
Oct 28, 2018
45
Hunter 31 Duncan Bay
If the boat needs an automatic bilge pump it would need to be on. That would of course be determined by how leaky or prone to collect rain water it is.
Oct 29, 2005
2,366
I hazard a suggestion that switch be off and 3 or 4 stage shore power charger be left on. You don't want the bilge pump flat lining the battery after couple of months if charger is off.
Ken Y
1,300
Columbia 36 Muskegon
As above. If the charger and bilge pump are wired direct to the battery, I'd turn the switch off. Assuming the charger is smart enough to not cook the batteries.
May 24, 2004
7,235
CC 30 South Florida
If the boat is going to be unattended for a few months I would say shut the 12V system down. Regarding the bilge pump, unless the boat has significant rain leaks or inflow of incidental water I would shut the pump down. Of course arrange for someone at the marina to take a look at the boat periodically. Charge the batteries fully and shut off the charger and disconnect the shore power cord. Batteries in good health should not self discharge significantly in a couple of months. A bilge pump is convenience item and if the owner is away he won't need the convenience. Should the boat develop a significant inflow of water the bilge pump would be useless anyway and marina neighbors observing the boat listing will be the primary safety resource.
