Welcome to the stage of confusion
known as Beneteau electrics. Stock Bene's are set up with all batteries in a single bank so as to allow charging from a single source, i.e. alternator or shore charger. You would be better served to have the banks separated into house bank and engine start so that if you draw the house bank down too far (and it will happen) you can still start the engine because the start batt is not in the house circuit. You'll need a combiner in order to charge both banks from a single source. Then, your switches will be, from the left, NEGATIVE, ENGINE START, HOUSE BANK. While aboard, leave all the switches on; at the slip, turn off the ENGINE START, and if you have things programmed, like radio/TV, or run the refrigerator, leave the HOUSE BANK on and the NEGATIVE on, too. You will also want to upgrade your alternator and regulator to allow faster charging and to avoid the engine running when the alternator is not putting out much current because the regulator is holding it back. Leave all switches on when charging. This is a very simplified explanation and you have a lot of reading and studying ahead of you.
