Battery Question
41
Oday 272le chatham ma
I have 2 Exide batteries on My O'Day 272. One doesn't seem to be charging. Will one battery start my diesel until I buy another one. The good one is fully charged.
bria46
Jan 15, 2011
286
Oday 272 Waukegan, IL, Sarasota, FL
I think yes, but don't hold the glow plug button down to long.
Dec 1, 1999
2,391
Hunter 28.5 Chesapeake Bay
One battery should easily start your diesel. I think it's a good idea to alternate starting your engine with each battery whenever you head out. This will give you a better idea of the conditon of the battery's ability to deliver cranking amps rather than testing voltage with a DVOM. It's quite possible to have a battery that is "fully charged" that cannot deliver the cranking amps needed to start the engine.
Jan 7, 2011
6,017
Oday 322 East Chicago, IN
Not sure what engine you have, but assuming a Small (18hp or so) diesel, you can open the compression levers to get the engine to turn over if you find yourself with a weak battery. Once it is turning over, close the levers . Needs 2 people, but it will help if the battery is too weak to turn the engine over.
Greg
