Hi;
I have a Hunter 340 with lots of Battery power. Meand'er has two pair of 6 volt cart batteries plus a 24 volt battery. I don't even know what the 24 volt is for or which of the 6 volt pairs are for start or house. The selector switch is only marked with 1 and two. I assume "1" is start but if I select "1" she has very little cranking power (has plenty on "2" or both). Running and charging on "1" makes no difference. The smart battery monitor ("Your-Meter" by Cruising Equipment Company) usually displays identical readings (volts, amps, amp hour draw and hours remaining), regardless of switch selection. I say usually because somehow I changed something an now it displays the 24 volt readings. I don't know how to change that back to monitor 12 volt.
How can the cranking be low on the "1" setting when it shows identical readings on "2" and "Both". I've had the boat for two years and it's always been this way. We have no marine services on our Island so I've procrastinated but needless to say it would be great to figure this all out.
Thanks. Jeremy
Any Thoughts or experience with this??
Thanks. Jeremy
