Cable Run
First I want to say that I don't know how much room is available under the 35.5 aft cabin berth. Our boat is the earlier H-35 and, as I remember it, the 35.5 has the berth slightly lower to provide more clearance between the matress and the overhead. As for cable runs, we used 00 throughout the battery area and to both the master switch (new high amperage Blue Sea) and the OEM house switch and fuses. For the run to the engine ground, alternator, and main panel, 16 ft x 2, I used #2 conductors. The plan is to install a sub pannel near the battery compartment (but not in it) to handle motor loads such as the forced air heater, autohelm, refrigeration, and water pump. This way the wire runs will be much shorter (from around 50 or 60 ft round trip to about 16 or 20 feet in the case of refrigeration). Motors like high voltage.The other battery types previously mentioned offer advantages in installation and placement but for shear low cost $/amp-hr/cycle the golf carts can't be beat. The book says to assume 700 (or 750?) 50 percent cycles but in actual use they can often beat that whereas some of the other types can have problems meeting their numbers. Also, with regard to voltage, our 'carts are now 8 years old and the voltages are still way up there in the 12.6 V range (after 24 hours stabilization period) and this is consistent with what I've read. The fully charged voltage/cycle curve for 'carts shows the voltage stays quite high and then makes a sudden drop toward the end of their life which is good. I've yet to see the beginning of the drop off and since they don't get used between the end of October and April/May I consider this exceptional service. These Trojans cost me $55 ea in '93; it's the rest of the installation that has cost the better part of $1,000. If you can make them fit - great. If not, well, you fall back to plan B.
