Still learning here. I was looking over my batteries and have a few questions. I have two batteries. The first is a STOWAWAY TOURNAMENT MARINE DUAL PURPOSE. The plate says "205 reserve capacity minutes @ 80". It goes on to say "designed for marine starting and trolloing motor deep cycle. 900 marine cranking amps at 32". This battery is hooked up to indicator #1 on the battery switch and I use it as my house battery.The second is a NORTH STATE BATTERY. All it states on the battery is "CA @ 32 = 665, CA @ 0 = 535". This battery is hooked up to indicator #2 on the battery switch and I use it as my starting battery.I have a battery charger that works off the AC at the slip. The batteries are closed cell (I never have to fill them).Here are my questions:1) The negative terminals of the two batteries are connected and then go to the battery switch. The positive terminals each go directly to the battery switch and are not connected to one another. Are these batteries in parralel or in series? What's the difference? What's best?2) Do I need to know the AH's? How would I calculate this since it's not written on the batteries?3) What type of maintainance do they need? Again, they are closed cell where I don't add water.4) Do the RCM's go down as the temperature goes up? It can get pretty hot in the lazarette where the batteries are located.Thanks,Joe Mullee
