Many places to put the batteries
I've read about several locations for the batteries. You might want to check the archieves.As I recall, they can be moved to the aft lazerette, but you'll need very long cables. Someone moved the starter battery to the port side in a compartment under the aft cabin berth. Someone else moved them next to the water heater. Others have gone to 6 volt batteries and scattered them about in places that make getting to them far easier.I have chosen to leave them where they are. However, I've replaced two of them with AGM deep cycle batteries, which require almost no maintenance. The starter battery is a regular wet-cell battery, that I check once every three months. Fortunately, I'm small enough to climb into the starboard lazerette, but I prefer not doing it unless absolutely necessary. :^(~ Happy trails and sails to you ~ _/) ~
