Battery info please
3,431
Seidelman S37 Slidell, La.
Just did a check with hygrometer on house bank. Batteries were at 100%, but had a float charge on until a few minutes before testing. All cells showed a consistant specific gravity of over 1.30, and were consistent. My question to the guru's is this. Even though I know I should let them sit for 24 hours before testing, does the consistency of all cells indicate the batteries are in pretty good shape? Or do I need to re-do.
Feb 6, 1998
11,772
Let them sit and re-test.. Like an open circuit voltage reading checking SG requires resting for the most accurate results..
Jun 6, 2006
6,990
All of them being consistant is a good sign. If they are over 1.3 then you have pretty strong acid. dead batteries have pure water and fully charged have the strongest acid. I would conclude from that fact that your batteries are charged as the acid will not get weaker with waiting for things to equalize
Joe A
Feb 4, 2008
117
Macgregor 26S Lake Wallenpaupack / EastCoast
You probably used a hydrometer
Not trying to be smart, but you probably used a hydrometer. A hygrometer measures humidity.
Feb 6, 1998
11,772
Not necessarily. I tested some 6V batts just last week that still had a surface charge. The cells were all even. I then hit it with half it's CCA rating for 15 seconds and waited an additional ten minutes. One cell was off by a large margin and well over the 50 points you want it to be less than. I only did this because the owner was on-board insisting my $$$$$$ analyzer was deficient and his SG readings were perfect. The battery could not support a carbon pile load test and had less than half the cranking capacity it should have had..
You'd often never know of an issue if not clearing the surface charge. 1.30 is a range certainly indicative of a fresh surface charge, warm temps or a thin plate or hybrid, starting/deep cycle, type battery. Most wet deep cycle cells are fully charged at about 1.265 SG but this does vary some by manufacturer. A difference between cells of more than 0.050 is an indication of a bad battery.
Before doing the test you should fill and dispense the hydrometer from the cell and back into the cell three to four times and do this at each cell. If the battery temps are not at about 80F you'll want to add 0.003 - 0.004 per every 10f above or below 80f..
Just like an OCV test you should wipe the surface charge or the readings can be erroneous.
Nigel Calder even puts this right in his book...
Nigel Calder said:
Following the discharge or charge, if the battery is left alone the acid and water will diffuse in and out of the plates, the battery will equalize internally, and the electrolyte will reach a homogeneous state. The only time a specific gravity reading will correlate accurately with a batteries state of charge is when the electrolyte is in the homogeneous state.
If the battery has been used vigorously , it can take up to 24 hours for the electrolyte to reach a stable state.
Oct 8, 2008
362
MacGregor/Venture 25 Winthrop Harbor, IL Drummond Island,MI
Dang MS....beat me to it ...you know your battery stuff too............good answer.
<butyl tape convert :)
