Battery house Bank Hunter 33 2009.
Jan 9, 2018
7
hunter 33 montreal
Hi!
How big is the space on a hunter 33 2009for the battery bank? What kind of battery can we put in?
Is there any pics?
Thanks.
Apr 27, 2016
19
Hunter 33 Detroit
I have 3 batteries under my starboard settee, two group 27s and one group 24. The boat was originally equipped with two batteries. Three is a tight fit, but by rotating my larger batteries 90 degrees I was able to make it work.
Jan 9, 2018
7
hunter 33 montreal
Hi Jeff!
That’s a good article. I never realise the importance of the orientation of the battery.
I will thing about it if i do not go with AGM.
Apr 27, 2016
19
Hunter 33 Detroit
Good point. Rotating my batteries actually corrected the orientation issue described in that article.
Sep 20, 2006
2,955
Hunter 38 Georgian Bay, Ontario, Canada
I have 4 Group 31 in the starboard settee in the aft compartment and 1 start battery in the forward compartment. The area is not tall enough to fit golf cart batteries so went with the 31's at 130 ah each. Start battery is for emergency reserve only.
Sep 20, 2006
2,955
Ok, so grey matter ain't quite what it used to be. 3 group 31's in aft compartment and 1 31 and start in forward. Drilled a hole thru to run cables for series.
