OK, now that we know that I'm not the person to ask about batteries
http://forums.sbo.sailboatowners.com/showthread.php?t=128420
and am about to head out on a long cruise to remote places with two AGM batteries that are probably on their last legs, what do I look for and how do I make a decision about whether to replace them proactively?
Voltmeter reads a hair under 14 V. when engine is running. Batteries read about 13.8 V. when first checked after main switch being off for 12-24 hours. I've almost never seen voltage below 13 spot checking while cruising. Engine always starts as fast as a car. I run both batteries together BTW and am just very careful about loads.
I plugged shore power into the boat a couple days ago after using the batteries for lights and running a vacuum. It had been sitting all winter. The charger went through its 3 cycles in about 5 minutes to maintenance level. Voltage 13.8.
Will I just wake up some morning in some remote place and find that everything is dead or will I see some change in these characteristics that will warn me that trouble is coming? A battery monitor isn't in the cards this year as I've spent too much. It's hard to justify anyway with my modest electrical usage.
If I just put my Harbor Freight battery tester (the one with the loading gizmo in it) on each battery, will that tell me anything useful?
