battery explosion
76
macgregor 25 Beaver lake, Rogers Arkansas
Was at the boat last Wednesday, worked a bit on a lifeline, played the raido and all was well. Went back out Saturday to sail, turned on some tunes but nothing happened. Radio, interior lights, running lights all dead. Went below to check connections and the battery and lo and behold the entire top of the battery was blown off. The entire electronics were turned off and the only thing active was a 40 watt solar panel running through a controller. There was no damage, the battery was in a box with a lid inside a stbd. compartment. It contained all the pieces and acid.
Any comments or suggestions will be appreciated. Never had a battery blow up before.
Jul 19, 2011
60
Chaser 29, Oday 23, Port Elgin, Ontario
Are you sure the controller was working? May have been accidentally shorted. What about heat. Charging batteries let off a highly flammable gas and the smallest spark.....
Just thinking out loud...
May 24, 2004
7,230
CC 30 South Florida
It happens. I gather you may be at a mooring and recharging with a solar panel. I'm afraid the box that may have contained the explosion may have been a contributing factor to it. Excessive gassing from a battery due to a faulty controller or just a high rate of charge after a number of cloudy days may have caused a concentration of gases inside the box. It just takes a loose or corroded battery connector to provide a spark and "kabun". Not endorsing that you do away with the box but perhaps drill a few holes in the top for ventlation and make sure the terminals are clean and tight. Do check the output voltage of that controller.
Glad you're safe. Sorry to hear about your mishap. Like my mother would say: "Aren't you glad...you weren't plugged into shorepower when you weren't only your boat?"
Another good reason to stay unplugged.
Dec 2, 2003
1,637
Hunter 376 Warsash, England --
Benny is right.
I used to have a 12V arc welding set. It took a massive drain from one very old battery so it was my practice to have a battery under the bench in my garage with the charger on max power.
One day a stray spark went down and there was a huge bang. Acid, marbles from the quick refill system and bits of battery were bouncing round the garage. I was drenched with acid from head to foot. Not good when (thankfully) wearing a mask. Took hours to wash everything down.
Couple of months later I got another battery and kept it out of the way to one side. Still had charger on full. Was welding away and BANG. This time I had inadvertently moved the wire and caused another spark.
Drat more washing down!
Anyone want to buy a nearly new welding set????
Hunter 34 Alameda CA
I've had two car batteries do the exact same thing. Both times they were right at their end of life and wouldn't start the car. I used the charger, unhooked it, closed the hood and hit the starter. Boom goes the dynamite! They were maintenance free. I figured the water level may have fallen below the tops of the plates and cranking the starter might have caused a spark igniting the hydrogen gas inside the battery case. I was lucky I was in the car and the hood was closed. Make sure you get the Costco size Arm and Hammer and sponge a solution of it around the area. Not all the acid might have been contained. If it fizzes, keep cleaning.
My third close call was my first job out of college. There was a Sears freezer that was used to store plastic jugs of hydrofluoric acid polymer solution in the lab. It was not explosion proof. The acid fumes dissoved the coils in the freezer and gave off hydrogen gas which exploded and blew the door completely off and stuck it in the drop ceiling. All the windows in the room and the clock face were etched opaque. Could'nt believe no one was in there at that exact moment. Hydrogen is potent stuff.
Glad you didn't get hurt.
Feb 7, 2010
76
Thanks for all the comments and well wishes. It sure could have been much worse. I've heard about batteries exploding all my life but never experienced it till now. They really will as I found out and there is no real good way to vent the hydrogen. Drats. I certainly don't want it to happen again.
zeehag
Mar 26, 2009
3,198
you were lucky. battery boxes work....smooth sailing.
Oct 24, 2011
258
Lancer 28 Grand Lake
I have never seen that. I have heard of it though. I worked as a mechanic, and heard of someones battery exploding. It blew right through the hood of their car. It left jagged bits of metal facing up the way in their hood. What had happend (the shop i worked at worked it out) they started up their car, and drove off, the starter motor didnt disengage from the starter ring, but kept turning. Being a DC motor, and now being powered by the engine, instead of taking power from the battery, it sent it back to the battery. Normaly the motor would just have burned out, but, the as the selenoid had also stuck at the exact same time (million to one shot) it fired the electricty back to the battery. Battery overcharged, another million to one shot, it exploded, and blew a hole in the hood of the car. By the time it did that, the starter motor had disintegrated, and broke up the flywheel, and the bell houseing. Most their was a huge repair bill.
They reconed it was all down to a selenoid that had jamed in the on position, and kept the starter engaged.
Oct 2, 2006
1,517
Jboat J24 commack
ARE last one was caused by and internal short in the plates
A 4 X 6 24 volt pack was getting funky so we did hydrometer testing and found a week cell
When replaced the caps to pull the bad unit it just went off and shot the the cap pretty violently
Feb 6, 1998
11,772
Most battery explosions occur in batteries at or beyond "end of life". It is most often caused by the positive and negative plates coming in contact with one another. This can happen from the batteries being of overly cheap construction and / or using poor quality separators. Sulfation and plate warping can also lead to this. Thermal run away can also lead to explosions. Chargers with battery temp sensors can help minimize this risk..
Batteries not sufficiently charged to full regularly, or stored & charged in temps above 80f can and will sulfate more quickly. Heat is one of the worst enemies of batteries. Sulfation causes the plates to wear and degrade. It also prevents current from flowing into and out of the battery as it should. The plates are not always evenly covered in sulfate so "hot spots" can develop in the plate which can lead to warping.
Due to vibrations on a boat or the process of equalization the lead sulfate can shed or fall off the plates into the bottom of the case. Automotive type batteries such as 12V group 24, 27, 31, 4D & 8D, have shorter cases and less room for lead sulfate to accumulate. 6V deep cycle batteries are taller and have space at the bottom for accumulating lead sulfate. When the sulfate builds up enough it can literally short between the plates. Lead plates can also fracture if they become over sulfated or eroded or if the battery is dropped or set down hard. When they fracture they drop into the bottom of the case and can short out with the another pos of neg plate.
This is why the industry usually uses 80% of new cranking amp capacity as the cut off for needing new batteries. Boaters with low to minimal current demand often push batteries well beyond their useful life and don't have them capacity tested often enough. Pushing batteries beyond this point can lead to consistently higher failure averages.
The best testing methods these days are either capacitance or pulsed load tests. The two big testers used in the industry are Midtronics (capacitance) and Argus (digital pulsed load). They can tell you exactly how many cranking amps the battery has. If you fall below 80% of the batteries stated or rated CCA or MCA rating the battery shows as failed and should be replaced. Marine batteries should ideally be tested with capacitance or pulsed load testers every 12 months. If you can find a shop that uses a Midtronics or Argus tester bring them there once per year and pay them for their time. It can be well worth it.
Many of these testers can print out test certificates for you to keep on hand to track the performance. You should start with a brand new set, get a baseline, and keep the certificates. If you start with one tester always use that same tester or brand.
Midtronics Test Certificate
Argus test Certificates: Batteries that are sulfated can often be extended for some time via controlled equalization charges. These batteries took two equalization runs, one 8 hours and one for four hours. At only 90% capacity the decision was made to retire them because at 5 years old, and never having been "equalized", they could have still been dangerous especially with all the newly shed sulfate in the bottom of the case.
That said ALL devices inside a battery compartment should be "ignition protected" or non-sparking devices.. This goes for fuses, battery chargers, switches, relays etc. etc. etc..... All battery compartments should be vented whether you have wet, AGM or GEL batteries...
-na -NA Anywhere USA
That was a good response from mainsail. It is also suggested that leaving a boat for a long period of time, shut the shore power and DC main off as well.
