Equalizing & Wiring
One of the many responses to this thread included:"Are you sure about the battery switch taking your battery out of the AC charging system? There was just a discussion on this subject over the last month or so."The verdict was that AC charger is totally independent of the battery switch. If I'm wrong that is fine, and I stand corrected."The "verdict" may be as useful as the OJ Simpson jury's decision.It all depends on how this particular boat was wired. While I agree that the verdict sounds correct, and is reasonable based on how the boat should have been wired (AC into charger, charger output to batteries - DC switch is only on load - DC - output from batteries), I think we've all seen some strange things out there.Having two different types of batteries is "frowned upon," but not all that unusual. The main reason for this is that gel cells require different charging voltage than wet cells. With one charger, you can't get two different output voltages (at least not yet - how many folks have wanted gel cell house banks and wet cell starting batteries?).To equalize the wet cells, it would be prudent to simply disconnect the gel cells from the charger. The output settings on the charger would need to be adjusted. I wonder what it is set on now? Either one of the battery banks are getting either undercharged or overcharged on a regular basis.That said, however, what we don't know is whether or not the original questioner has a combiner, a single or dual or triple output charger, a charger with an echo charge, or any of the information necessary to make an informed decision for him. I would recommend that he personally trace his wires and understand basic battery management as it pertains to his individual situation.As always, Calder's Manual comes to mind, as well as another response who quoted Xantrex, a very reputable charger manufacturer. Another good source is the Ample Power Primer, available online fom Ample Power. Use Google search to find it, download it and read it.
