Ok, all you electro-techo-experts: I've got a 2000 H380. Freedom Inverter/Charger, Solar Panel for the charging battery.Everything has been hunky-dory (on power) since we received the boat. I noticed in the past month, however, that the house batteries show a topped-off voltage around 13.5 volts. The starter battery sits around 15 volts.All of the batteries were replaced in the past 9 months.Is the starter battery possibly a bad battery, or should I look at the solar panel or charger?While on sail (with inverter on) and afterwards, all the batteries seem to hold a charge well. I'm just concerned with the high voltage on the one battery.-David
