My O'day 25 has one type 24M battery. It is used to start my OB and so far it has been charged only by running my Yamaha T9.9 Outboard.
Simple enough but I only run the outboard for about 30 minutes per day sail and never above 50% throttle.
While sailing the only current draw is the depth sounder and GPS.
The T9.9 specs says it will charge at 6 amps so at 50% throttle I expect it is charging less than 3 amps, probably more like 2 amps.
This does not sound like enough charging to replenish the starting load of two starts per sailing trip.
Do I need some kind of auxiliary charger?
Thanks
Thanks
