Replaced Mine
Paul,I have a C320 and had to replaced my charger after I cooked off a couple of batteries. What I saw was the original Pro-mariner charger was rapidly cycling. It kept the charge a bit high but not into overcharge on my circuit breaker panel voltmeter. when I looked at the charger in the port lazerette I could see the needle just bouncing so I assume that the charger would start to chage, see the chage was fine, stop the charge cycle, instantly decide to charge and repeat. Each cycle was a about 1/2 a second. When I looked at the batteries I'd see a small bubble every few second. When I turned off the charger the voltmeter showed a full charge (not charging / overcharged) after 10 to 15 minutes so when you return to your boat everything may look normal. I replaced the charger with a NewMar charger. Fit right in the same slot as the old charger. Now there is no more cycling, no more bubbles in the batteries and the voltmeter is at 100% charge. Good luck.
