Maine,
I have left two messages through your Compass website with no response so thought I would try the direct approach here. Want to upgrade my 30 amp charger to a bigger one and was going to order the Sterling 60 amp off your website. Then I wondered if I should go bigger than 60 and if so what charger would you recommend? Have a 390 AH bank that I plan to upgrade to the Trojan 6 volts that you recommend which would be 450ah? Want to be able to bulk charge this bank quickly with a Honda 2000. Have a solar panel for much of the charging. Does an 80 amp charger make sense in this situation?
Thanks bob
Thanks bob
