He battery charger has failed, it appears to have been the original. I am set up with two banks a house bank with two deep cycle and a starting battery. The original unit is rated 15amp DC, I can find 12 amp and 20 amp. Thoughts on which way to go?
From the West Marine site comes sound advice:He battery charger has failed, it appears to have been the original. I am set up with two banks a house bank with two deep cycle and a starting battery. The original unit is rated 15amp DC, I can find 12 amp and 20 amp. Thoughts on which way to go?
Not knowing your usage profile or battery configuration makes a good specific recommendation impossible.What size charger do I need?
Deciding how big your charger needs to be is determined by the size and type of your batteries, and whether your boat has a continuous or intermittent source of AC power to run your charger. Boats that spend most of their week at a dock, constantly hooked up to shore power, require smaller chargers. You need enough capacity to run the continuous loads on your battery system, like DC refrigeration (frequently the biggest user of battery power) and lights, plus enough power to float-charge your batteries. A good rule is to have enough amperage to equal the sum of the DC loads plus 10 percent of the amp-hour capacity of the batteries.
If you’re cruising or anchored out, and aren’t plugged in except intermittently, you will want enough capacity to recharge in the time you have available, if possible. You need enough juice to replace the power consumed by all the DC loads, as above, plus an average charge rate equaling the amp hours required divided by the hours available. Maximum amperage that batteries can accept during the Bulk Phase of the charging cycle vary depending on battery chemistry: flooded batteries can accept a charge rate of up to 25 percent of C; gel batteries have a higher acceptance rate of as much as 30 percent; AGM batteries accept the highest charging amps, as much as 40 percent of C.
Yes, but if you have lead acid, get a NOCO Genius. I have a 3 Gen rated for 3 banks at 10 Amps per bank. It is a 30 Amp rated unit, with pure sine control and 8 stage charging. I have 3 group 24 batteries and lots of 10W lights and with my radio (and sometimes stereo) and two batteries charged in 2 hrs 15 minutes, then float maintained for 12 hrs to see if they took a good charge. They did, very, very happy with this charger, customer service is excellent.In the absence of any info indicating what size batteries, I.e., capacity, go with the largest. Undercharging batteries is the quickest way to kill them.
