Hello,
I am looking for a little advice. I purchased my boat a few years ago with the understanding that the battery charger didn't work. I didn't have shore power and would run 2 daisy chained extension cords down to the boat and plug in a portable charger. I recently had shore power installed and want to be able to just "plug in" without having to use the portable charger. I took apart the seat that the existing charger was mounted to so I could get to it and discovered the fuse was out, so I replaced that and powered it on. This charger is a NewMar ABC 12-15 which is a 2 bank 15 amp charger.
When powered on, the light came on, so I put a multimeter to it and it seemed like it was putting out the right voltage but the ammeter wasn't showing any amperage, so I did some more testing and finally called the previous owner and he said that ammeter was probably all that is broken.
I wrote the company to inquire about it and they said they have a flat repair rate ($164) but to me that rate and shipping together would cost almost as much or more than as a new unit, perhaps by Guest or another company at least. So I opened up the casing and it looks like a pretty simple swap out to install a new ammeter, I inquired about just purchasing an ammeter and haven't gotten a response, which irritates me that I got a prompt response the first time and now feel as if I am being ignored.
So, my questions are these:
How should I proceeed? Is it worth the $164 + shipping costs both ways to have it serviced repaired? I don't really think so.
Do I try to repair it myself? This is my initial hunch, do I need the exact same ammeter or could I get one that is the same size and amperage (i.e. 0-15 amps). Does it matter if I put one in that is 0-25 amps if it is easier/cheaper to find and fits?
Or, do I purchase a new one? What brands are trustworthy and have good service or product life? I will need a 2 bank charger and I guess somewhere around 15 amps I guess.
Thanks in advance for your advice,
Jon
Jon
