Thanks, but...
Ross, I used 12v to determine voltage drop. I'm not sure what you mean by using a dead battery to determine if the engine will start. No matter; I don't have a battery. The boat is in my back yard getting a complete refit. When it's ready for launch I'll buy the batteries.camaraderie, I did double the lengths, though I forgot the first few times I went through the calculations. Quite a shock to realize my relatively inexpensive cable, when the length doubled, now was very expensive! Guy, the primary route, battery to switch to starter to battery is 22'. The secondary/emergency route house battery to switch to starter to house battery is 26.5'. The engine is an MD11c that should draw 140 amps. The starting battery is close to the engine but there was no place for the main switch panel close to the engine; thus the long run. but... my question; How much voltage drop is acceptable for a starter motor without compromising it's function significantly? Will it turn over the engine adequately at 11.9v? 11.8v? 11.5v? Using 12v, the 4% drop in the secondary circuit will give me 11.52v. 12v is 75% discharge according to East Penn's data. (A level of discharge I hope to avoid.) A 4% drop (secondary circuit, 1g cable) then gives me 11.52v. Will that be OK?Sorry to sound so picky but if I get the boat in the water and find I need to do it over there will be a lot more work than doing it right now. Thanks much for your help.Geoff
