Hi Roger,
Lesley & I cruise full time on Spring Fever and organise our sparks: -
We have an isolated 55 amp/hour battery solely for the engine, plus two 85 amp/hour liesure batteries from which all other current is drawn, the latter have an off/b1/b2/both switch wired in, but to be honest it\'s either both or neither, so they\'re effectively used as a single battery.
Since the dynostart charging/starting element of the solenoid died a couple of years ago, the dyno is now a starter only, with all three batteries charging from the alternator. This isn\'t the standard 35 amp/hr unit, but a 65 amp/hr one off which came off a Volkswagen car (polo I think, though it may\'ve been a Golf) it\'s exactly the same size and other than swapping the belt pulley over was a straight exchange. We\'ve also got one of those smart regulators fitted, though other than lookng pretty, I\'m not sure if it does anything (voltage tests whilst charging seem unaffected whether it\'s switched on or off). It\'s a very simple system, insofar as we start the engine, un-isolate the starter battery so that it charges, then after 30 - 45 minutes we isolate it again and leave it off until next time we need to start up. we also have a cheap 6 or 8 amp car battery charger which we connect whenever shore power is available.
Up until this summer when we reached the Med. we always reckoned that running the engine for 45-60 minutes a day was enough to keep us topped up and that we could safely sit at anchor for 48 - 60 hours without a recharge. this summer, despite new batteries, the daily charge requirement has reached 1.5 - 2 hours a day, with a maximum 24 - 36 hours without charging. We\'re putting this down to higher water/air temperatures making the fridge draw too high and hope to help matters by reducing the size/inceasing the insulation to our fridge (it is a fairly big one). Also we\'re going to invest in a 2-stroke suitcase generator, as we can by one for £100 and it has a built in battery charger, the idea is that we can run this for a couple of hours each day, rather than the engine and hopefully improve things by around 20%.
This decision was made after polling lots of other livaboards about alternative energy sources and getting the following results: -
A solar panel set-p would cost us £6-700 and probably improve things by 25-30%
A wind generator would probably cost nearer £900 for a similar gain
Towed water generators are a complete waste of money, we came across five people with them and all were willing to sell theirs to us for half the price new.
Hope this helps
Bob carlisle.
rogervjohnson <rogervjohnson@...> wrote:
Hello All - I\'m curious as to the best way to electrically power your
boat. Do you have a battery bank (of two or more combined batteries),
or do you have one specific battery as your house battery and another
to start your inboard?
And what\'s the best way (most reliable) to recharge the aforementioned
when under sail for extended periods? Wind generator? Water
generator? Solar?
Thanks much for your help and advice!
Roger
