I have been a Link-10 user for quite a number of years now and have found it a huge aid in maintaining my battery bank, in particular learning how much individual appliances draw. There is great comfort in knowing how much you are sucking out of the batteries, even down to sitting at anchor and seeing if I reduce the brightness on the TV it saves 0.5Ah. We have a genset on board and generally I never let the batteries discharge anywhere near 50%... well as far as I can guess. Guess being the important point, spending a lot of time away from shore power (home is a river mooring) I start to distrust the Link-10 and don't want to run the genset all day to get back to being confident of being close to full charge. So regular charging is the order of the day.
So recently I've been reading up on the SmartGauge which by all accounts gives an accurate state of charge. Whether this is by magic or not I don't care as long as its accurate, if the military are using it then my feeling is that it must work and that the science behind it must be sound.
Hence we have one device that gives us a pretty accurate measure of amps being drawn and another that gives a pretty accurate SOC. But what would really assist me in planning day to day battery charging is a good knowledge of what my battery bank capacity actually is, given it reduces over time and my batteries are years old now. Knowing my Ah draw is good, knowing SOC is good but neither on it's on tells me whether to recharge before I leave the boat for a trip ashore or wait till I get back.
So, the question that I would like to answer, and I'm sure the answer is far more complicated than anticipated, is this...
If I have both a SmartGauge and an Ah Counter, both correctly wired, assuming the SmartGauge has settled in and learnt the bank and the Ah counter is as well configured as the average boater can (Peukert etc), then would the following hold good.
If I have no current draw and all forms of charging are switched off, then I read the SOC from SmartGauge, say 95%. I then make a note of the Ah count (or zero it) and apply typical current draw (fridge etc) but no charging. Wait until SOC has reduced by 25%, say down to 70% note the Ah count over this period. Can I now say this is approx a quarter of my bank capacity.
Hence my bank capacity is 4 x the amps drawn.
Does that work or, given the complexity of batteries, just fantacy?
If it is a decent rule of thumb then keeping track of bank capacity year on year should be an easy thing to monitor with both devices fitted.
Thoughts?
Thoughts?
