Yes it is true. I am having battery issues again. Last year I installed an 8D for my house bank. I already have a Group 27 for my Starter. They are both gels.I have replaced the original charger that burned out with a True Charge 20+. It has a remote panel and a remote temperature sensor.The batteries do fine on the charger.On my recent trip though, the house battery would not charge up even with much engine time. The boat is a Hunter 376 1998 with a Yanmar 50 amp internally regulated alternator. Hunter used a solenoid relay to combine the batteries when the engine runs to allow both to charge from the alternator. There is no other crossover and each battery has an independent off / on swith.After running most of the day, we anchored out and my house battery only lasted an hour or two. The next day I ran my generator and charged it. During the day motorsailing, I was getting a low voltage alert on my vhf.I checked and had voltage around high 13's on both batteries. I am thinking that the starter battery is triggering the alternator to slow down prior to the house battery charging. Also, the gel house battery had a removable cap so I peeked in. The gel was solidified on the top and looked like hardened and cracked wax. I switched my 8D back to the original 4D and had similiar results with a low voltage alarm while motoring.Has anyone had any similiar results or know who I can consult to get expert opinion or diagnosis. We are in the Chesapeake on Maryland's eastern shore.Mike D
