Gene, Probably more important than Ah is insulation. I was shocked when I took the icebox out of Lyric. stainless steel inner box and a plywood outer bow with a whopping 1 inch of Styrofoam around it. No wonder the beer wouldn't stay cold! We built a custom
 box out of fiberglass. It stair steps up the side of the hull with the lowest part of the box closest to the engine. It was sized to hold 6 1.5 Liter plastic bottles for cold drinks. Next step outboard was about 6 or so inches higher and separated by a plastic
 fiddle. That was used for meats and produce. Last step was smaller and the closest to the outboard. We were able to surround this with a minimum of three inches of foam. Not a whole lot of area to work with so we built the aft end of the box directly against
 the plywood cabin/cockpit bulkhead. We built a false bulkhead with 4 inches of foam between the two.We were never able to make ice but the mixers were cold enough for cocktails and we were a very popular boat because of it.For those not familiar with the saying, "The perfect boat sleeps 2, eats 4, drinks 6 and your wife can single-hand it."From:
AlbinVega@yahoogroups.com AlbinVega@yahoogroups.com on behalf of gene_neill@... [AlbinVega]
Sent: Monday, October 23, 2017 2:11 PM
To:
Subject: [AlbinVega] Re: Batteries under the V berth?
 This message is eligible for Automatic Cleanup! (
AlbinVega@yahoogroups.com)
Add cleanup rule |
More info
That is good news, both about the weight distribution AND about your power generation/consumption. I'm still working on my "energy budget"!
May I ask, what is the Ah capacity of your two batteries (I assume they are six volt, since they are golf cart batteries?) Also do you know the power draw of your refrigerator, and do you sail in hot climates, or cold? I definitely want a fridge also, and we
 will be in the tropics.
