Finally! Today I winched those 100# 6-volt batteries into the cockpit and then got them into the bilge. And the bilge covers fit without removing those heavy stringers. Still need the tie downs and the cover for the fuse(left).
Then I installed the new #6 cable from the battery switch to the panel. Now that was fun! Cable runs under the cockpit, across the fuel tank, through that cabinet which happens to have my A/C in the way, and up to the panel. That panel and those bus bars were not made for #6 wire.
You can see that I installed a battery fuse directly onto the back of the battery switch. What is missing is the cable to the starter.
I did test the install including the Link 2000 with the Heart inverter/charger. I left it plugged to 15 amp shorepower for just a short time because it was programmed for the old AGMs. I forgot to take the book.
So there you go, all 1/0 cable tied to 225aH worth of 6v wet-cells. And a problem I never had with AGMs and Gels? Little holes suddenly appearing in my good Levis.
