Some possibilities
That boat comes with a stock 50-amp alternator. At 2800 rpm, it should produce at least 40 amps. Four hours of running means 160 amp-hours.That's not a lot of amp-hours. The crummy little batteries that the original owner replaced probably held about 160 amp-hours total.I'll bet the previous owner had a slip with shore power. That's what I use to charge up my 380 amp-hour bank. If I had to rely on the alternator alone... well, you can do the math.You are likely keeping your boat on a mooring or at a slip w/o shore power. If you're going to keep this battery bank, you need to find some alternate power sources.Solar cells are steady producers of electricity, but you'll need a lot of them and they are expensive. You'll also need to leave most of them at the dock, since there aren't a lot of places to install them on a 33-foot sloop. A wind generator is the best choice. A generator is harder to install than solar cells, but it will make enough juice to keep your batteries charged, if you're a weekend sailor.Or, you could go back to the smaller bank. But if you have a fridge, you won't be able to run it, or will have to ration its operation.Even a 100-amp alternator wouldn't be the best solution, unless you want to spend your tranquil hours at anchor watching diesel fumes come out the back of your boat.Paulsv Escape Artisth336
