I just came aboard and the batteries were showing "zero" on the amp meter. I looked at the TrueCharge 10 Amp Multi-Stage Battery Charger and it was giving out a light sequence that suggests the batteries are damaged. The battery selector switch was set on "ALL". When I switched between #1 and #2 the amp meter remained at "zero". I tested both the starting and house bateries with the multi-meter and got under 6.6 volts on both. I have three house batteries (gel) run in parralel that amount to 291 AH and are seven years old. The middle battery in this group was hot to the touch. The starting battery is isolated from the house batteries.
The first thing I've done is turned off the battery charger. Is there anything else I should be doing from a safety standpoint as I try to figure out this problem? Should I unhook the cables that parralel the house group? The charger has been turned off for about an hour and the middle battery is still hot.
A little over two weeks ago I left on a six day sail and had no issues. My Yanmar 3GMF has the standard 35 amp alternator. I spent four of the nights on the hook. I returned nine days ago at which time I turned on the battery charger when I closed up. Right before I left I installed a new refrigeration unit. When I left the boat I left the refrigertor switched on the the DC side. The unit is a Norcold which has an automatic AC/DC relay switch so I don't think it would have caused this problem. The refrigerator was plenty cold when I got here indicating it was running off the AC side.
Any help, suggestions, advice on what caused the problem and how to fix it is greatly appreciated.
Joe Mullee
Joe Mullee
