I have a system where there are two house batteries on a 1/2 switch and a starting battery on its own separate on/off switch.
In the battery compartment it appears to my eye that the starting battery is isolated. All three batteries are connected on the negative side.
I am going through house batteries rather quickly - 1 to 2 years life on 27s. I am suspicious of my Charles smart charger, which is normally on at the slip. I do have have meters, but they read high even when the charger is off, so it is tough to rely on the meters, yet they read full charge at 17 volts - too high, if the meter is accurate. I also have found electrolyte in the wood battery supports. I am suspicious that I may be overcharging even though the water levels are not low.
I am considering putting a new smart charger in and want recommendations. With my setup as described above how many banks do I need to pan for? I have a reefer, but very little 12v beyond that. How many amps do I need?
