C
Capt'n BoB
Ran accross an interesting concept for battery maintenance.Is any body using a Pluse Tech battery conditioner for your boat's battery system.Here is their marketing material - sounds interesting12V Solar/AC Marine Conditioner$119.95MS-12RPulseTech's patented pulse waveform technolgy is proven to reduce and prevent sulfation buildup on lead acid batteries, whether the batteries are in use or in storage. The primary cause of battery failure is the buildup of lead sulfate crystals on the battery plates. Lead sulfate forms as a result of normal battery function, but over time a residue of sulfate will remain on the battery plates and crystallize. This crystallized sulfate is no longer available in the battery electrolyte, and insulates the active battery plate material from the remaining active electrolyte, leading to the eventual 'death' of the battery. With the PulseTech Solargizer, regulated pulses of DC current are fed into the battery, causing sulfate residue to break down and return to the electrolyte solution, boosting battery performance and prolonging functional lifespan. The MS12 battery conditioner is used with the attached solar panel or the included AC adapter for maximum flexibility, on any 12 volt lead acid battery. The MS series Solargizers are constructed with marine-grade components for optimum durability in harsh oceanic conditions.
