The standard cruising furling main is cut with a shallow leach, and does not really require battens as there is no roach to support. If you are experiancing any fluttering you should be able to control via the leach tension line.
Thanks for the reply. Yesterday I discussed this issue with Doyle Sails. They checked my mast and determined that the opening is not wide enough to accommodate battens. End of discussion!!
No , but when the guy came to the boat he spend considerable time measuring the mast. The manual lists the opening as 3.0 centimeters. You can get manuals in PDF at. www.seldenmast.com navigate to manuals from the top of the page..
