Battens needed
Squidd
Sep 26, 2011
890
AMF Alcort Paceship PY26 Washburn Wi. Apostle Islands
Just picked up a new/used (new to me) sail but it didn't come with battens..
It marked as from a Cat 27 and has the same P and E measurements as my original tired Paceship sail (also much "crispier") but it didn't come with battens...
Pockets are much skinnier than Paceship flat nylon battens would fit almost looks like maybe a 3/8" round fiberglass rod was used as batten...???
Is this common size for cat 27...?
Can I just use a 3/8" -1/2" fiber rod as batten...??
Squidd
Sep 26, 2011
890
I may have answered my own question, but would like confirmation before I order...
I didn't find any 3/8" "round" battens but did find 5/8" flat/tapered battens which look like they may fit...
Probably the ones...??
Squidd
Sep 26, 2011
890
Squidd
Sep 26, 2011
890
Thanks Rich... That's similar to what I was looking at/found...
Beneteau 323 Annapolis MD
...but would like confirmation before I order... I didn't find any 3/8" "round" battens but did find 5/8" flat/tapered battens which look like they may fit... Probably the ones...??
You can't get the cross-section strength in a flat one that would fit into the round pocket. You CAN get round ones if you get on the computer- or check with a sail loft. Too small will break and puncture your sail.
