It's said that one should not allow a battery to discharge past 12.1 volts.
However, how do you measure voltage under load?
At rest, batt 1 reads 12.6 volts. With instruments and nav gear then activated, says 12.3 volts. Add LED nav lights, down to 12.2. Engage glow plugs, down to 11.8.
Similar result with batt 2, but slightly less.
Do I have to unload the battery to test voltage/state of charge?
Both are your average group 27 deep cycle wet cell. 5 and 6 years old. Maintained. No anomalies.
I'd like to be able to monitor state of charge from the helm, using the chart plotter which has a readout available. Have verified voltage reading is accurate, by comparing to a multimeter attached directly to selected batt.
