Bartow 16 winch disassembly
1
Irwin 41 Ketch St Simons Island
I have one Bartow 16 winch on my mizzen. It's the only one on the boat. I need to grease it however I can't figure out how to get ti apart. The other small winches on the boat have an allen screw in the center which releases the drum, but this one doesn't. There's just a smooth surface deep in the center like maybe there is a cover? I poked at it but I can't find a way to move/remove it. Does anyone know any thing about this winch?
Thanks,
Jim.
Jun 9, 2008
1,860
- -- -Bayfield
Yep. Just push down on the rubber boot and that will release a spring catch and then lift the drum from the base.
RichH
Feb 14, 2005
4,773
The best way to repair a 'push button' Barlow winch is throw it into a trash can !!!!!
Yes, you push down on that 'smooth cover-like' object down in the center of the bore and this will release the spring that holds the barrel to the spindle. The problem with such 'push button' Barlow winches is that they do separate under the right conditions and under high load. I had one come apart when applying a heavy load, the barrel separated from the spindle, the barrel traveled along the tailed line, hit me square in the face, knocked me out momentarily (saved by my harness from going overboard), smashed my glasses 'into' my face, blood all over the deck, only took 8 stitches to close an additional 'eyebrow' ..... all because the spring under that so-called push-button Barlow became weakened and could no longer hold the barrel to the spindle when at heavy load. .... the worst part is that this was my PRIMARY mast base winch, a winch that was used many times to help get me up the mast.
After this incident, all my 'push-button' Barlow winches went directly to the trash can; if this winch of yours turns out to be one of the 'push button' release type Barlow's, I strongly urge you to also 'trash it'.
992
Oday 25 Gibraltar
Wow! I'm glad I replaced mine. I didn't care for the plastic composite base and spindle either.
Rich
RichH
Feb 14, 2005
4,773
Rich
That 'plastic composite' base ... or composite top flange on the 'barrel' on some models ... is the 'giveaway' that you have the 'push button' type...
Jul 15, 2010
3
Oday 26 McCall, ID
The Barlow 16s have a plastic/nylon spindle that will swell if any oil or grease is used on them. Just wash with fresh water frequently.
