Hi All:My boat is going into it's third season, and I have not been able to get bottom paint to stick to the bottom........ it comes off in sheets during the season.Lake Erie sailingVC 17 paintInterlux is going to pick up the tab for removing the VC 17, sanding, and application of a barrier coat, then Micron Extra. I plan to be back in salt water in the next couple of years, so this might be a fortuitous situation, as I understand that VC 17 does not like salt water.However, are there any drawbacks to the barrier coat. Hunter has given their blessing regarding the sanding, but, does barrier coating cause any future maintenance problems ? Is there any annual maintenance I need to be concerned with ? Or, if I want to switch paints as I get to warmer weather and water, will there be any considerations ?Thanks for any help........ Jeff
